11 Apr 2024 09:42 PM
Used the optical and the arc, none of them worked. Sky cable going from tv to sky box. Bose hdmi trying in every hdmi port on the tv, still no sound
11 Apr 2024 09:46 PM
hi @amindy
Was the optical from the SKY Q box to the Bose Sound system ?
What setting di dyou have in
:Home - Settings - Setup - Audio Visual
Digital audio output Optical
if it is set to Dolby Digital can you try setting it to Normal
11 Apr 2024 09:52 PM
Just done that as you said and changed it to normal and nothing changed
11 Apr 2024 09:55 PM - last edited: 11 Apr 2024 09:56 PM
hmm - I have no idea why that would not work unless there is something technically failing in either the Q box or the Bose system (or I guess a faulty cable) , assuming you can select the Optical input OK on the Bose system
11 Apr 2024 09:57 PM
No idea thanks for your help
11 Apr 2024 09:59 PM
Have you tried changing the input of the soundbar from toslink to hdmi or vice versa
11 Apr 2024 10:09 PM
Not sure what toslink is? Its a Bose sound link, so 5.1 surround sound.
11 Apr 2024 10:10 PM
Sorry, toslink is Optical Audio. It's used interchangeably.
11 Apr 2024 10:13 PM
Posted by a Superuser, not a Sky employee. Find out more@amindy although it may not help as online manuals for Bose equipment can be thin on the gound, if you can give use the model number it might helps us understand more
