This discussion topic has been answered Discussion topic: Using Sky Go to record Sky Q
Message posted on 08 Sep 2023 08:02 AM
Re: Using Sky Go to record Sky Q
That is excellent.
Thank you for confirming my thoughts.
Message posted on 01 Feb 2024 07:24 PM
Well unfortunately it did used to tell you there was a clash on the APP meaning that once again SKY goes backwards
Message posted on 01 Feb 2024 07:32 PM
Well unfortunately it did used to tell you there was a clash on the APP meaning that once again SKY goes backwards. The SKY+ app, when opening it would tell you of any clashes. The APP is now defunct with no replacement. Why? Things should be moving forwards not backwards. How about a monthly fee moving backwards to compensate?
Message posted on 01 Feb 2024 08:28 PM
@ginger101010 Sky go was updated to accommodate Sky Q which rarely will have recording clashes due to being able to record 6 channel at one time whilst watching a seventh the Sky+ app is defunct as Sky are no longer supporting Sky+ (HD) now hence the reason thereare no updates for the app and no replacement simply because Sky no longer support the system I am sure in a few years time when satellite TV is on its way out that Sky Q will go the sxame way
Message posted on 02 Feb 2024 12:17 AM
Good point about the clash thing. Never seen one since getting Q. I'd forgotten they existed in the olden tymes.
Message posted on 02 Feb 2024 06:23 AM
I believe you also can't remotely set a recording for BBC channels when away using the Sky Q app but you could and still can if you have it using the old Sky+ app.
Obviously less of an issue these days with downloads and apps but still a step backwards...
Message posted on 02 Feb 2024 08:14 AM
@who10uk wrote:I believe you also can't remotely set a recording for BBC channels when away using the Sky Q app but you could and still can if you have it using the old Sky+ app.
Incorrect - you can't download from BBC channels to your phone or tablet remotely, but you can still set a recording to your Sky Q box; just need to make sure you've selected the 'Record to Sky Box' tab in the app
Message posted on 02 Feb 2024 09:06 AM
@who10uk I take it you mean the Sky Go app as the Sky Q app was discontinued years ago but any way as @Invisiblename says on the old Q app you could record BBC channels and on the Sky Go app you can still record the BBC channels when away from home you just need to chose the option record to Sky box
Message posted on 02 Feb 2024 01:45 PM
Last time I was out of the country I thought I had set a number of recordings for the 2nd week of my holiday.
When I returned none of these recordings had happened and there was no sign that I had set them I.e. no failed recordings.
I still had free space on my 2Tb box.
