Discussion topic: Upgrade to Sky Q
Message posted on 17 Apr 2024 09:33 PM
Upgrade to Sky Q
We presently use a Tecnomate to transfer the sky feed to a tv upstairs. We don't want a mini box. Will the Tecnomate still work with a Q box ?
Message posted on 17 Apr 2024 09:42 PM
Re: Upgrade to Sky Q
hi @jono65
As Technomate make a variety of devices I think you need to give us more details of what it is (maybe a model number) and how it connects - if it connectes to SKY HD via RF then the answer is no
Althoough not an answer to your specific question you may wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
Message posted on 17 Apr 2024 09:45 PM
There is ways to use RF for sky q, but that requires a HDMI splitter that circumvents HDCP and then an HDMI to RF adapter which has an IR blaster built in.
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Message posted on 17 Apr 2024 09:55 PM - last edited: 17 Apr 2024 09:57 PM
Assuming you have one of these
You can use the below device to strip the HDCP and use the EDID from the TV which will then negotiate a handshake with HDCP cert from the TV with the Q box
Mods delete if this is illegal as I'm not sure on the legality of it.
Message posted on 17 Apr 2024 09:59 PM
The Technomate is a TM-50HD POE. I can't see if it fits into the sky box with an rf link as I can't see the rear of the sky box as it's in a cabinet.
Message posted on 17 Apr 2024 10:08 PM - last edited: 17 Apr 2024 10:27 PM
This should work, as it has HDMI input from Sky Q box and then output to the TV, if Sky+HD worked on it then it should work on Sky Q as Sky+HD had HDCP also, albeit an older HDCP specification. But hopefully it should work.
Message posted on 17 Apr 2024 10:29 PM
Thank you for your responses. Appreciated.
