2
This discussion topic has been answered Discussion topic: Unable to view or delete recordings
This message was authored by: 1972pc
Re: Unable to view or delete recordings
Hi @1972pc
If you also cannot make new recordings you could have a hard drive issue.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
@1972pc
What's happening when you try? Any error message? What have you tried already (reboot)?
Hi @1972pc
Answered - Go to Answer
