Discussion topic: SKY Q Box switches off (Yellow LED)
Message posted on 22 Apr 2024 04:48 PM
Hi,
My Sky Q box switches off but won't switch back on.
I have to turn off at the power and reboot.
Sometimes does this two to 3 times a day, it also does it while recording.
Any suggestions?
Message posted on 22 Apr 2024 04:52 PM
Re: SKY Q Box switches off (Yellow LED)
Just a bit more info.
Remote works ok and new Batteries fitted.
Software has been updated to latest.
Message posted on 22 Apr 2024 08:24 PM
Hi @AdrianH72
Message posted on 22 Apr 2024 09:12 PM
Have you tried changing the standby mode from eco to active ?
I have had issues with my boxes as I'm not with sky broadband, kept getting stuck in standby until I changed that option
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
