Discussion topic: Unable to view ITV2
Message posted on 19 Oct 2023 08:07 PM
Unable to view ITV2
For some reason I am unable to view ITV2 sky channel 118. This is the only channel that I cant view, and obviously I can't record from this channel either. I have followed on screen instructions about re booting the sky q box but to no avail.
Any advice would be much appreciated.
Message posted on 20 Oct 2023 07:53 AM
Re: Unable to view ITV2
Are you seeing any error message on screen when you try to watch 118? Are you able to watch ITV2+1 on 218, or ITV2 in SD on (I think) 816?
Message posted on 20 Oct 2023 08:32 AM
@Daniel0210 @Thanks for the response. I've just checked and bothe channel 816 and 218 are working fine, it seems like it is just 118 I have a problem with
The error message showing on screen when I put 118 on says "this channel is currently affected with your satellite signal. For help press ?"
Message posted on 20 Oct 2023 09:11 AM
You will need an engineer visit to check the dish even if it's only ITV2 HD that is affected.
The only other channels broadcast on the same frequency are a few ITV1 HD regions (Granada, Wales, Tyne Tees, Westcountry) so if you're not in those regions only ITV2 HD will be affected.
@StephenB76
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. Just to make you aware, if you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
Message posted on 06 Nov 2023 08:54 PM
Exactly same issue itv2 constantly buffering and jittery. But 816 and 218 are fine. But ITVX also not
Playing properly. Thanks for heads up on other channel numbers.
Message posted on 15 Jul 2024 06:41 PM
Sign in Join
SIGN IN
Welcome!Log into your account
your username
your password
Forgot your password?
CREATE AN ACCOUNT
SIGN UP
Welcome!Register for an account
your email
your username
A password will be e-mailed to you.
PASSWORD RECOVERY
Recover your password
your email
goosed
Home News Entertainment News
NewsEntertainment NewsTV
How To Add ITV To Sky In Ireland For Euro 2024
By Marty -14th June 2024
adding itv to sky box in ireland
It’s time for another big summer of football. If there’s a game on ITV you’re looking forward to or you’ve just had enough of Didi Hamann or Kevin Doyle (sorry lads, I actually quite like you, honest), you can tune their channels in on your Sky Box. We’ve got you covered with this simple guide to adding ITV to Sky.
Table of Contents
How To Watch ITV On Sky
Why Watch ITV Coverage of Euro 2024?
ITV doesn’t come preloaded on your Sky box. However, you can manually add TV channels in settings once you know the configuration. Here’s how you do this.
Turn on your Sky box
Press “Services” on your Sky remote
Select “Options” from the menu.
Scroll sideways to the “Add channel” tab and enter these settings:
Frequency: 10.891
Polarisation: H
Symbol Rate: 22.0
FEC: 5/6
Standard: DVB-S
Modulation Scheme: QPSK
Once all of these are set, press the yellow button to find channels
Once the search completes, you’ll see loads of “ITV” options.
Highlight one and press the yellow button
Press the green button to save your settings
Finally, press the “Select” button.
Now that you’ve added ITV to your Sky box, it’s time to tune into the football. Unfortunately, adding a channel manually doesn’t assign it a channel number. This means the only way to access ITV is through the Sky menus. Here’s how.
Choose “Options” from the menu
Scroll sideways to the “Other channels” tab
Highlight “ITV” and press the “Select” button on your Sky remote.
This has worked for me now
