Discussion topic: Mini box keeps freezing
Message posted on 15 Jul 2024 06:10 PM
My mini box keep freezing
Message posted on 15 Jul 2024 06:19 PM
Re: Mini box keeps freezing
Hi @Raj131
Reboot the mini as above.
