134
This discussion topic has been answered Discussion topic: Unable to activate Discovery Plus
This message was authored by: nutterdogs
Re: Unable to activate Discovery Plus
we all seem to have the same problem activation is not working. Hopefully they will fix it asap as so many people are having the same  thing
This message was authored by: Emzbail
I have the exact same issue with both Discovery plus and Paramount plus.
I've been emailing Paramount who are responsive but haven't been able to resolve yet.
Having seen this I'm hopefully it's a wider issue and will be solved soon. Fingers crossed!
This worked for me:
www.sky.com/shop/activate/discoveryplus
Worked straight away with no issues.
im not trying to work out what the Paramount link is as I guess the Discovery one based on a Disney link shared on another thread.
If anyone has the Paramount link per the above please share.
This message was authored by: sjchappers77
This worked for me too, thanks! Completely different link to what Sky have been sending me so thanks for sharing.
This message was authored by: lindsaygalloway
@Emzbail
Wow thank you 🙏 so much that worked!!
What is the world coming to when a Sky customer has to provide a solution to other Sky customers because the Sky Technical team can only provide the same link over and over again that clearly isn't working! Or request you do an app refresh on your TV!!
If you have not already done so. Do you know how we can provide this link to everyone on this thread? Apologies I'm new to the community
Glad it helped.
I've still got Paramount to fix.
I think a Sky moderator will promote it to a solution at some stage on this thread.
This message was authored by: Sparky1958
Friday 17th October still having this issue
This message was authored by: peter+t20
sadly the link didnt work for me. i logged into sky account, then clicked on your link and it said 400 bad request ( laptop using edge )
hopefully sky themselves are also working on a solution, as sky text earlier to say to activate discovery or it maybe cancelled !
See my reply below
@peter+t20
Try opening the link through Google or Safari maybe?
Tried that and took vpn off
This message was authored by: RUDD
Discovery +
Struggling to get on discovery + tried to activate still no luck
Just followes the link that emzbail and is now able to watch discovery plus thanks for sharing Emzbail
This message was authored by: Becky149
Thanks so much, this worked straight away.
Sorry Emzbail could you share the link again. Thank you
Answered - Go to Answer
