Discussion topic: Ultra hd not showing
Message posted on 17 Sep 2023 11:58 AM
I am pressing the red button to get the ultra HD as it says but when i press this it's not giving the the UHD option as it usually does? Trying to watch leeds Vs millwall
Message posted on 17 Sep 2023 12:02 PM
Re: Ultra hd not showing
@Jacob2 wrote:I am pressing the red button to get the ultra HD as it says but when i press this it's not giving the the UHD option as it usually does? Trying to watch leeds Vs millwall
Working for me
Message posted on 17 Sep 2023 12:03 PM
Hi @Jacob2
Are you sure that your Q box is still set to 2160p?
If so try accessing the UHD football through the Home menu Sports option.
Message posted on 17 Sep 2023 12:04 PM
On your Sky Q box, go to;
Home>Sport>Live sport this week and select the MillwallvLeeds tile, that shows Uhd and it it launch it in uhd.
Message posted on 17 Sep 2023 12:06 PM
Have you checked your box is still set for uhd? Also try getting to uhd the other route. Find the match in the guide, try "i" and look for other showings.
