Discussion topic: Return
Message posted on 17 Sep 2023 12:13 PM
Return
Hi there you've asked me to return my box but you've not sent me the boxes or return labels
Message posted on 17 Sep 2023 12:14 PM - last edited: 17 Sep 2023 12:15 PM
Re: Return
Hi @SKYCD73A
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
See the following link for all Sky returns information.
https://www.sky.com/help/articles/return-tv-broadband.
If necessary you can use you own Packaging and also print your own labels.
Ensure that you keep proof of posting as the Sky return system handled by Unipart has delays and is not as reliable as would be desired.
Re: Return
@SKYCD73A
If you’ve successfully cancelled your subscription Sky should send out returns packaging near the end of the cancellation period, [14 days for Broadband hub and 31 days for Sky Q box(es)], to the address that the subscription was registered at.
Note:~ If you’ve switched from Sky Q to Sky Glass the packaging is usually sent out after 31 days in case you change your mind about Glass.
You can use any packaging as long as it’s secure and you may want to put a note inside with your account number and a list of equipment that is included. This link explains about how to receive an email with your return labels through Royal Mail.
If you haven’t anything suitable contact Sky again and see if they’ll re-send. Keep your proof of posting safe and indefinitely and if you use Royal Mail’s collect from home service, keep a record of the tracking number.
