Discussion topic: USB cable
This message was authored by: PJW1983
USB cable
Sky usb damaged how do I get replacement
Re: USB cable
hi @PJW1983
SKY Q doesn't use USB but do you mean an  HDMI cable to connect to the TV?
If it is the HDMI cable then you can get  them from many sources in different lengths - for 4K you need an HDMI V2.0 or better
Re: USB cable
@PJW1983  Sky Q doesn't need USB cables,, are you referring to the cable from the Q box to the TV? if so you can purchase an HDMI cable from any decent electrical retailer.
This message was authored by: bob1234
Re: USB cable
@PJW1983Yes you can buy these in many lengths BUT don't pay an exorbitant amount for one a basic one costing about £6 is just as good as ones costing 10 times as much, infact just looked and found one at 100 times the price.
This message was authored by: Ciaran1976
Re: USB cable
You can buy them on Amazon - don't go for hte expensive ones though.
