Discussion topic: USB cable
Message posted on 06 Jul 2023 02:48 PM
USB cable
Sky usb damaged how do I get replacement
Message posted on 06 Jul 2023 02:51 PM - last edited: 06 Jul 2023 02:52 PM
Re: USB cable
Message posted on 06 Jul 2023 02:52 PM
Re: USB cable
@PJW1983 Sky Q doesn't need USB cables,, are you referring to the cable from the Q box to the TV? if so you can purchase an HDMI cable from any decent electrical retailer.
Message posted on 06 Jul 2023 03:19 PM
Re: USB cable
@PJW1983Yes you can buy these in many lengths BUT don't pay an exorbitant amount for one a basic one costing about £6 is just as good as ones costing 10 times as much, infact just looked and found one at 100 times the price.
Message posted on 06 Jul 2023 03:25 PM
Re: USB cable
You can buy them on Amazon - don't go for hte expensive ones though.
