Discussion topic: Sky q not found
This message was authored by: ratbag12
Sky q not found
Hi
Can someone help please
Just had sky q installed but I can't connect to the sky go app it just keeps saying not found
Re: Sky q not found
@ratbag12 wrote:
Hi
Hi @ratbag12
Do you have the Sky Q monthly Multiscreen subscription ?
Without this you cannot connect the Sky Go App to your Q box.
This message was authored by: JordanBGoblin
Re: Sky q not found
Also on the sky remote next to the main box:
Press home
Scroll down to settings
Check what does it say on the right.
Repairing TV, broadband and computer devices from 20 years in the UK, Czech Republic, Eastern Europe.
Avatar for ratbag12
Re: Sky q not found
No is that why ?
Re: Sky q not found
@ratbag12 wrote:
No is that why ?
Hi @ratbag12
Without Sky Q Multiscreen you cannot connect to your Q box with the Sky App on any device.
You can use Sky Go to access Sky Online content but cannot connect to your Q box to view the TV Guide,  recordings or any Q box content.
Avatar for ratbag12
Re: Sky q not found
Thanks for that cheers
