Discussion topic: UHD not working
Message posted on 27 Oct 2023 12:29 PM
UHD not working
UHD not working on my Sky Q box
Message posted on 27 Oct 2023 12:44 PM - last edited: 27 Oct 2023 12:45 PM
Re: UHD not working
hi @Melvin1930
Please can you give us a bit more info.
Has it worked before ?
Are you getting an error when trying to select 2160 ? if so do you get it for both 8 bit & 10 bit
What is the make & model of your TV?
Have you tried a full power down restart of both your Q box & TV ?
Message posted on 27 Oct 2023 12:50 PM
Re: UHD not working
I had a replacement box and now UHD not working
Message posted on 27 Oct 2023 12:57 PM
Re: UHD not working
Thanks, so in addition to the other questions I have asked please tell us what the Hardware version shows in:
Message posted on 27 Oct 2023 01:01 PM
Re: UHD not working
Q190.000.16.00L
Message posted on 27 Oct 2023 01:04 PM - last edited: 27 Oct 2023 01:05 PM
Re: UHD not working
@Melvin1930 wrote:
Q190.000.16.00L
hi @Melvin1930
Thanks but that is is Software version (which is actually out of date) but likel to get updated overnight
The Hardware version should be one of these:
If it is 32Cxxx then you have an older 1TB non-UHD Box
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply)
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box
What actually is the problem you are getting ?
Message posted on 27 Oct 2023 01:07 PM
Re: UHD not working
message: App not working try later!
Message posted on 27 Oct 2023 01:39 PM
Re: UHD not working
It's not an app. On your Sky TV home page ~ Home - Settings - System Info - Hardware Version.
