Discussion topic: Sky Q mini box frozen (constant red light) main box is ok
Message posted on 25 Aug 2023 10:35 AM
Sky Q mini box has a constant red light. Main box working fine. Tried resetting both boxes, checked cables connection etc. Controller now flashing.
Message posted on 25 Aug 2023 10:38 AM - last edited: 25 Aug 2023 10:39 AM
Re: Sky Q mini box frozen (constant red light) main box is ok
Hi @Gill
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 25 Aug 2023 10:47 AM
Got the same problem. Why can't we talk to someone?
Message posted on 25 Aug 2023 10:52 AM - last edited: 25 Aug 2023 10:52 AM
Hi @GrannySuemc
Have you tried switching the Q box on with standby button on the front of the Q box (Amber led)?
Message posted on 25 Aug 2023 11:19 AM
Tried everything suggested.
disconnected box and reconnected. Pressed on button, red button turned green but after the set up blue page with the house, when it says the screen will go blank, press house. The button goes red and nothing happens. House button doesn't work, standby button doesn't work. New batteries in remote.
Message posted on 27 Oct 2023 02:22 PM
I have been on this forum followed all reset steps and the box will not respond. I have updated software on main box and again tried to reset the box but to no avail.
