5
This discussion topic has been answered Discussion topic: UHD SkyQ
This message was authored by: BigAl29
UHD SkyQ
I have just purchased an LG UHD TV but cannot get UHD on it, the highest resolution I can get on the Q box 10.80.
I have been paying for HD previously
This message was authored by: Laing1 Answer
Re: UHD SkyQ
@BigAl29 check the link below for what Q box you have the original 1TB boxes were non UHD so you may have to upgrade your box
https://www.sky.com/help/articles/sky-software-updates
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: UHD SkyQ
This message was authored by: Doc5907
Re: UHD SkyQ
Are you now subscribed to the UHD add in ?
Sky Q 1TB UHD
LG TV
Sky Mobile
Avatar for BigAl29
Level 2 icon
Re: UHD SkyQ
@Doc5907  Apparently I need another box, the standard 1t box does not support UHD.
more money for sky got to pay £99 for UHD BOX 😭
Avatar for BigAl29
Level 2 icon
Re: UHD SkyQ
@Laing1 I need another box apparently, the basic box is not uhd 👍👍
This message was authored by: Q-tips
Re: UHD SkyQ
Be aware that a lot of content tagged by Sky as UHD is actually upscaled and not native UHD. To view these programmes in upscaled UHD you don't need a Sky UHD add-on as your TV will do the same job if you tell it to.
Sky should label content more accurately in the EPG: their own regulations say they will label upscaled content as "Remastered for UHD" but this isn't happening, presumably because they want to deceive the uninitiated into thinking they are watching UHD content.
32B12C 2TB UHD Q box • Mini boxes x2 (32D0B2) • 2022 LG C2 OLED TV • Software vQ230.000.14.00L • Gigaclear gigabit FTTH broadband (935Mbps up/down) • Linksys Velop tri-band router; 3 mesh nodes • All Q boxes fully Cat6 hardwired • Q wi-fi disabled • Q picture/audio processing disabled (no sound bar) • Pixellation cured by Q170 but back again with Q190 and now every few minutes with Q210 and Q220 live broadcasts and recordings on all boxes
