Discussion topic: Tv signals
Message posted on 08 Aug 2024 08:52 PM
Tv signals
Intermittent signal
Message posted on 08 Aug 2024 09:03 PM
Re: Tv signals
@Mark309 wrote:
Intermittent signal
If this is loss of Satellite signal @Mark309
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
Message posted on 08 Aug 2024 09:07 PM
Re: Tv signals
. The picture breaks up. Loses sound and pauses. Unable to watch programmes at all. Blue message comes up saying signal it being received then comes back on again. Happening for 5 days now
Message posted on 08 Aug 2024 09:09 PM
Re: Tv signals
Message posted on 08 Aug 2024 09:11 PM
Re: Tv signals
@Mark309
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” it relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue as suggested by @oldfella
