Discussion topic: Sky Q box not connecting to network.
Message posted on 08 Aug 2024 08:44 PM
- Sky q multi room swcond box not working and showing error below. Have followed instructions on screen and making no difference?
Message posted on 08 Aug 2024 08:59 PM
Re: Sky Q box not connecting to network.
Reboot the mini as above.
