Discussion topic: Tv picture
This message was authored by: Juliesowerby
Tv picture
Hi I am having issues with the picture on my tv whenever I watch SKY channels, the picture glitches and pixelated
can you help
thanks
Re: Tv picture
can you help
thanks
Hi @Juliesowerby
If the issue continues best to contact Sky for an Engineer to check your Dish
