6
This discussion topic has been answered Discussion topic: Tv issue
This message was authored by: Steve452
Tv issue
Fed up with having to reboot our Wi-Fi as soon as our sky Q works.. resetting constantly although it's shows all is fine when I check.
Re: Tv issue
If this is issues connecting your Q box to your router @Steve452   Then try the following..
Re: Tv issue
Avatar for Steve452
Re: Tv issue
I've taken all those steps several times, and I'm still having the same issues,
Re: Tv issue
Use powerlines
Avatar for Steve452
Re: Tv issue
Which are what exactly please?
Re: Tv issue
https://youtu.be/ywQeJCa3jl8
Re: Tv issue
So did those steps work in the end?
