This discussion topic has been answered Discussion topic: Tv issue
Message posted on ‎23 Mar 2025 08:28 PM
Fed up with having to reboot our Wi-Fi as soon as our sky Q works.. resetting constantly although it's shows all is fine when I check.
Message posted on ‎23 Mar 2025 08:52 PM
If this is issues connecting your Q box to your router @Steve452 Then try the following..
Message posted on ‎24 Mar 2025 03:41 AM
Re: Tv issue
I've taken all those steps several times, and I'm still having the same issues,
Message posted on ‎24 Mar 2025 05:34 AM
Re: Tv issue
Use powerlines
Message posted on ‎24 Mar 2025 11:10 AM
Re: Tv issue
Which are what exactly please?
Message posted on ‎24 Mar 2025 02:31 PM
Re: Tv issue
@Steve452 wrote:Which are what exactly please?
Message posted on ‎25 Mar 2025 07:35 AM
Re: Tv issue
@Steve452 wrote:I've taken all those steps several times, and I'm still having the same issues,
So did those steps work in the end?
