Discussion topic: Tv Scedule not working
This message was authored by: Kazzaslee
Has anyone else had problems with their tv program schedule saying waiting for tv schedule for 3 days now
Re: Tv Scedule not working
@Kazzaslee have you tried restarting your Sky Q box? Put it in standby, then turn off at the plug for 30 seconds.
Avatar for Kazzaslee
Yeah tried rebooting it leaving it off for 10 mins but still comes up the same thing
Hi! Can you check the standby status of your Sky Q box please?
Your Sky Q box should be on Eco mode. If it isn't, your Sky Q box could be missing TV Guide information. To check and change your settings, try the following steps:
Press Home on your Sky Q remote.
Select Settings, Setup, then Preferences.
On Standby Mode, there are 3 options: None, Active and Eco. If your Sky Q box isn’t on Eco mode, select Eco, and a tick will appear.
Press Home to exit the menu.
Please let me know how you get on.
@Kazzaslee
Who are you directing that reply to?
Where have you seen that? This link explains the Standby settings you're referring to.
https://www.sky.com/help/articles/using-the-standby-settings
