Discussion topic: Troubleshooting after a power cut
Message posted on 14 Apr 2023 12:23 PM
Have returned from holiday and no recordings have been done since Jan 10th can't watch old recordings snd the sky box has changed to sky Deutschland
Message posted on 14 Apr 2023 04:36 PM
Re: Troubleshooting after a power cut
@PurplePaul Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 15 Apr 2023 08:38 AM
The Sky Duetschland is nothing to worry about, that is just the name on the TV has applied to the input source for Sky, it won't effect your viewing.
In regards to your recordings please fully reboot your box by putting it in stanbdy and turning it off at the mains at the wall
Once you've rebooted the box try to record something that is being aired live to make sure it will record furthur programs ok.
My views are my own and I will assist where possible.
Sky Q 2TB UHD, 2X Mini Box, Sky BB UF1, Booster 4
I am just a customer, If I've got something wrong feel free to tell me, If I've something right mark it as an answer
Message posted on 15 Apr 2023 09:08 AM
That mesage is originating from your TV.
As described in this Sky help article;
What to do if you see the message 'Sky Deutschland' appearing on your TV screen
This message is being picked up by your TV via the HDMI connection to your Sky Q box and is labelling the HDMI connection, to fix this simply go into your TV settings, and rename the HDMI connection title.
'Sky Deutschland' appearing on your TV screen | Sky Help | Sky.com
Try repowering your Sky Q main box, by removing the power for a few minutes.
I would suggest doing the same with the TV also.
