Discussion topic: Trooli router connectivity
Message posted on 20 May 2024 08:08 PM
Today I replaced my Skynrouter with one from Trooli. I've successfully connected my main Sky Q box to it but cannot connect the minibox in my bedroom. Somehow or other even when I do manage to get a connection it loses this when I turn the bedroom TV off and back on.
Has anyone else had connectivity issues when they've changed to a non Sky router?
Message posted on 20 May 2024 08:10 PM
Re: Trooli router connectivity
@Delboyrattler Your post has been moved from the Sky Broadband forum as it's not a Sky Broadband service your connecting to your Q boxes.
Message posted on 20 May 2024 08:58 PM
@Delboyrattler your mini boxes will not coonect to the trooli router by wifi they will need to connect to your Sky Q main box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 20 May 2024 09:31 PM
Yes I thought that might be the case. I'm wondering if there's a weak signal between the minibox and the Q one as when I had a Sky router I had to have a booster in my hallway. However, I can't connect the booster to the Q box! I'm presuming I'm correct in thinking a minibox does in fact work with a Trooli router!
Message posted on 20 May 2024 09:35 PM
Why can't you connect the WiFi booster to the Q box? I assume it is a Q WiFi booster?
Message posted on 20 May 2024 10:00 PM
It's not for the want of trying! I've pressed the wps buttons on them but the booster doesn't connect
