Discussion topic: Transferring my Sky subscription to a new smart computer.
This message was authored by: Bramble7
I have just bought a new smart TV because my old one was too small and even with a sound bar the sound wasn't clear enough. I thought transferring my Sky package would a simple matter but I am finding it difficult.  At the moment I have voice only for one channel but a blank screen. Doe anyone know how I should go about it ?
This message was authored by: NickNewark
Re: Transferring my Sky subscription to a new smart computer.
How are you getting Sky, is it via Sky Q, Stream??
hi @Bramble7
Assuming you have SKY Q, regarding the blank screen try pressing the following keys on the SKY Remote in sequence
Home 1 0 8 0 Home
@Bramble7  I'm confused by your post as getting a new TV does not involve a transfer of your Sky TV package?
Avatar for Bramble7
Thanks everybody. I thought it would be a simple transfer and that is what it turned out to be. After  my initial attempts , I went for a short walk, came back and made the post on the community. Then went back to have another look and there it was waiting for me. as someone asked yes I receive Sy through a Q box. I can only  think that I did't give it long enough.
