Discussion topic: Mini box connectivity
Message posted on 24 Apr 2025 08:18 PM
Got a new virgin route the main sky box is connected but cannot get the two mini boxes to connect
Message posted on 24 Apr 2025 08:40 PM
Re: Mini box connectivity
@trackman01 how are you trying to connect the mini's ?
As you have virgin as your broadband supplier you need to connect the mini boxes to the main Q box by using the wps button
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 24 Apr 2025 09:17 PM
Hi @trackman01
Reboot the minis as above.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or or previously connected mini).
