Discussion topic: To not working
This message was authored by: Momoeded
To not working
Tv
I cannot get my channel 167 up on my TV
it's never happened before I put the no in and I've also gone on to to guide and scrolled down to the channel still doesn't work can anyone help
Re: To not working
@Momoeded
Never watched it. I've just flicked over to that channel and it's working fine here on Sky Q.
Perhaps try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Re: To not working
@Momoeded wrote:
Tv
Hi @Momoeded
Thats Disc.Science.
Working OK here.
Have you tried rebooting your Q box.
