Discussion topic: Series link keeps cancelling
This message was authored by: GRU22
Hi guys any idea how too fix the series link issue.
It's cancelled my links on a number of channels l, or its recorded old episodes.
I've tried removing link and putting it back on?
Re: Series link keeps cancelling
Hi @GRU22
The majority of series link failures or repeats are normally down to the Host Broadcaster coding incorrect link information.   Main line channels however don't often make mistakes.
You could try the following procedure.
First make a note of all your series links in ~Recordings - Scheduled.
Then first remove just the series link from each scheduled recording. ( Don't remove or cancel the recording at this stage, just remove the series link)
After you have removed all the series links then Cancel every scheduled recording.
Once the scheduled section is completely empty reboot the Q box.
Once the box is completely back up and running re add all your series links.
See how it goes.
Avatar for GRU22
Thank you, that looks to have worked on a couple of recordings.
Cheers for replying to my post, great help.
