2
This discussion topic has been answered Discussion topic: Technical fault
This message was authored by: Yellow9373
Technical fault
Technical fault. Switched on and off. Took viewing card out and wiped and back in. Still not working
Re: Technical fault
Hi @Yellow9373
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Re: Technical fault
Hi @Yellow9373
Avatar for Yellow9373
Level 0 icon
Re: Technical fault
Done. Keeps doing this on and off over last 4 days
Answered - Go to Answer
