Discussion topic: Netflix loads and then stops playing after a few seconds
Message posted on 09 Dec 2023 10:56 AM
We load netflix through Sky Q,it starts playing the programme and then just stops after a couple of seconds.
Message posted on 09 Dec 2023 11:07 AM
Re: Netflix loads and then stops playing after a few seconds
Hi @Pete91163
First try reloading Netflix.
To do this open Netflix on your Q box and go to the Left Hand menu.
Scroll down to the bottom and then scroll right and select Get help.
On the next screen there is the option to reload Netflix.
When this is done reboot your Q box.
When using Netflix and exiting always best to use the Exit Netflix at the lower Right hand side of the Netflix menu.
