Discussion topic: TNT sport . Not in HD
Message posted on 02 Nov 2024 01:31 PM
Why is my new TNT Sports subscription NOT in HD? How can I fix it?
Message posted on 02 Nov 2024 01:36 PM
Re: TNT sport . Not in HD
@Asbo+56 wrote:Why is my new TNT Sports subscription NOT in HD? How can I fix it?
hi @Asbo+56
Are you selecting the HD versions of the channels & if so what message do you get - on my box the HD versions are much further down the channel lkist
(BTW I don't subscribe to TNT so not too familiar with the channels themselves)
Message posted on 02 Nov 2024 01:36 PM - last edited: 02 Nov 2024 01:38 PM
@Asbo+56 who have you subscribed through and what channel number are you trying if through Sky the HD channels should swap to the 400's but may not have swapped so look in the 800's
Message posted on 11 Nov 2024 07:44 PM
Having same issue after recently subscribed. Any help appreciated
Message posted on 11 Nov 2024 08:25 PM
Who did you recently subscribe via, Sky or BT/EE ?
Message posted on 11 Nov 2024 08:31 PM
Message posted on 13 Nov 2024 06:48 PM
Im having this issue as well. Sky Ireland, subscribed to TNT / Premier Sports through Sky themselves. TNT HD channels in the 800's stating that I need to upgrade my package to view, even though I have a UHD / HD package. I can watch some games in UHD through TNT Ulitimate (via red button on the standard definition channel) but the day-to-day stuff is all standard definition. Any help or fixes would be appreciated.
Message posted on 16 Nov 2024 11:52 AM
I am getting no where with sky on the phone. Sending signals to my box and being told to wait 48 hours.
A joke at this stage
Message posted on 18 Nov 2024 06:54 PM
After two weeks I finally got the solution. The removed my sports extra package and then re added it.
Hopefully this will fix others having the same Issue
Message posted on 18 Nov 2024 07:20 PM
Cheers, I'll give them a shout tomorrow again and mention this as a possible solution.
Message posted on 01 Mar 2025 04:18 PM
I'm just off a very frustrating call where I tried to suggest this solution to sky. After reboot box and sending signals, ended with this is a known problem so sending to supervisor to resolve technical issue so I'm none the wiser. Did anyone else have success getting this issue resolved?
Message posted on 08 Nov 2025 05:55 PM
I've still not got this solved... works fine on Sky Go but not on Sky Q.
