Discussion topic: TNT Sports
This message was authored by: Barbara635
TNT Sports
I pay BT for the TNT Sports channels but for the last 3 weeks I haven't been able to view them through my Sky Q system.   The screens are pixilated and keep freeezing then lose signal altogether.   All of the other SKY channels work fine.  BT have advised me to contact Sky.
Re: TNT Sports
Yep, been quite a bit of this.
Assuming a box reboot (unplug at the mains for at least 5 minutes), doesn't fix it, then your dish may well be slightly out of alignment and you will need an engineer.
In the meantime you can watch via discovery+ in up to UHD assuming you have activated it. The app is on your Q box.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
