Discussion topic: Starlink - connection
Message posted on 29 Nov 2024 08:39 PM
Hi all,
I need some help. Just got Starlink internet but having terrible issues connecting my mini boxes. The main Sky Q box appears fine but the mini boxes connect for a few seconds and then lose network connection. Read a few blogs and nothing works. Don't want to have to run Ethernet cables around but any help would be well received. Happy with Starlink but now another hurdle.
Message posted on 29 Nov 2024 08:47 PM
Re: Starlink - connection
@Huffy69 wrote:
Hi all,
Hi @Huffy69
The mini boxes need to connect to the main Q box (and not your Starlink Network)
Reboot the minis as above.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or previously connected mini).
