11
This discussion topic has been answered Discussion topic: Sound muted for some adverts
This message was authored by: Steven26
Advocate adverts have no sound whatsoever. I change channel and the volume comes back. No rhyme or reason ?
This message was authored by: xenon81 Answer
Re: Sound muted for some adverts
Yes for example there is an advert for a car dealership (Trade Centre UK) that is delibrately silent. I think it makes people look at the TV to see why it's gone silent, instead of looking at their phones during the ads!
This message was authored by: daveNOS
@Steven26 Why do you think thats an issue with Sky Broadband(the section you've posted in)?
Avatar for Steven26
Its a sky tv issue not broadband issue. Is there a way to delete and try again ?
I've moved your post @Steven26
Avatar for Steven26
Cheers 👍
@Steven26
What TV platform are you using?
This message was authored by: nolte
What is the product they are selling?
Is it anything to do with hearing loss?
Is it just ads from one company with no sound?
If you leave it on the station, Are the next ads OK?
ROI sky Q Customer.
Avatar for Steven26
I have a sky q box which shows adverts on various channels where the muting is random.
Is it possible that advertising companies mute their adverts randomly for effect ?
This message was authored by: Lesley7771
The same is happening for me. If you leave it the sound comes back on the next advert
Avatar for Steven26
Thanks. For me it sometimes happens for more than 1 advert. I change channel and that sorts the mute out straight away.
While some adverts like the Trade Centre car adverts are deliberately silent (https://makeitsticky.co.uk/folio/trade-centre-wales-sssshhhh/ ) if you're finding other adverts are affected and the sound returns after changing channel that sounds more like a technical fault of some kind.
