Discussion topic: Sound drop out on Sky Q Formula 1
Message posted on 04 Mar 2023 01:25 PM
I am watching Formula I channel on my SKY Q box and the commentary sound keeps dropping out. No issues on any other channels. How can I fix this? I have done a hard reset power down. No difference
Message posted on 04 Mar 2023 01:26 PM - last edited: 04 Mar 2023 01:27 PM
Re: Sound drop out on Sky Q Formula 1
Hi @stewart.a When you're doing a reset, are you completely unplugged from the wall for at least 30 seconds?
Also, have you checked for any possible software updates?:
Go to Settings, then System Info, and highlight Software version.
Choose Setup and then select Software download.
Your box will start to download the latest software. This can take up to 10 minutes.
To check the status of the software download, go to Settings, then System info, and highlight Software version.
When it says "Software update successful" press the Standby button on your remote.
When your box restarts, follow the on-screen messages. You'll then be on the latest software version.
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Message posted on 04 Mar 2023 02:26 PM
Thanks @Ecosse I'll give the software update a go. Although it seems to be ok on Formula 1. It was the previous Formula 2 sprint that I kept dropping out. So seems like a technical problem at Bahrain!
Message posted on 04 Mar 2023 05:51 PM
Let us know how you get on.
Good luck.
