Discussion topic: Software download issue
Message posted on 12 Nov 2024 05:16 PM
trying to download the software update on my skyq box and it's taking a lot longer than the 10 minutes. Currently on about 40. Any suggestions?
Message posted on 12 Nov 2024 05:38 PM
Re: Software download issue
Hi @Zoe98 Did you follow the correct procedure 1. set off the software update. 2. Carry on viewing on the Sky Q box for at least 30 minutes. 3. Put the Sky Q box in Standby. The Sky Q box should then restart and perform the software update (if required). Note if the software is already up to date, all you have done is a power recycle of the box. Why did you attempt the software update?
Message posted on 12 Nov 2024 05:40 PM
Hi there - I downloaded because my live tv and none of the apps were working. There's just nothing happening now so not sure what to do
Message posted on 12 Nov 2024 05:52 PM - last edited: 12 Nov 2024 05:54 PM
Hi @Zoe98 What is the current status of the box and lights. If it is off, what happens when you turn it on using the power button on the actual box.
My Sky Q box is stuck in standby | Sky Help | Sky.com | Sky Help | Sky.com
