Discussion topic: Slow Download Speed
Message posted on 04 Nov 2024 07:38 PM
Slow Download Speed
All of a sudden download speed of on demand episodes has dropped, it has been absolutely fine for weeks and now it is taking 2 hours to download a single episode. Our WiFi speeds are fine and we are on Virgin Broadband
Message posted on 04 Nov 2024 07:50 PM
Re: Slow Download Speed
Hi @Joek95
