Discussion topic: Slow Download Speed
This message was authored by Joek95 This message was authored by: Joek95
Slow Download Speed
All of a sudden download speed of on demand episodes has dropped, it has been absolutely fine for weeks and now it is taking 2 hours to download a single episode. Our WiFi speeds are fine and we are on Virgin Broadband
Re: Slow Download Speed
Hi @Joek95
