Discussion topic: Skyq box
This message was authored by: Sheldon419
Skyq box
Have a new Samsung QN95D 65in ,cannot for the life of me get it to work ,it's in the bedroom ,I press the qbox which is on green but can't get sky tv .it says error MR001
any advice is appriciated
ta
Re: Skyq box
I presume you have a mini box in the bedroom attached to the TV?
Avatar for Sheldon419
Re: Skyq box
Yer it's a small qbox attached to,I've had them years and never used them
Re: Skyq box
Do you have a multiscreen subscription?
Re: Skyq box
As far as I know I have, i reccolect chatting for ages and got talked into havin 3 qboxes but now you mention it I don't really trust them so I'll give them a ring now
Re: Skyq box
Hi @Sheldon419
You can view all your Sky package content on your Q box in the Home Menu.
My Sky at the bottom.
Easy to check if you have Sky Multiscreen.
If you have
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Re: Skyq box
Thanks for your reply if only just got to read is and yes it was very helpful as I'm up and running at last , thankyou pal
