Discussion topic: Skyq bbc iplayer issues
Message posted on 02 Jun 2026 09:09 PM
Re: Skyq bbc iplayer issues
It's definitely the football icon as if you scroll down so that the match of the day is not showing then go left to the menu it works fine seems we will have to wait until the end of the World Cup for it to be fixed!
Message posted on 18 Jun 2026 07:13 PM
Mine has resolved itself for now.
Don't know if there was an auto update
Message posted on 18 Jun 2026 07:17 PM
Hi. Thanks for the info, yes I agree they seem to have fixed the issue.
Message posted on 18 Jun 2026 08:49 PM
@00011000 wrote:
Hi, I have ben having issues with the bbc iplatey app on my skyq box. The home page cursor is very slow and jerry through the left hand menu causing it to skip past the selection such as selecting search . This only happens on this menu and page and is fine typing after this page. All software appears upto date and I've tried to force update the box manually.
My bbc ipayer app on our SkyQ box is working fine be watching over night football maches on it for last couple of days actually , no problem.navigating though the various pages. Definitely not having the problems you describe.
Message posted on 19 Jun 2026 07:13 AM
@DaveDrizen wrote:
@00011000 wrote:
Hi, I have ben having issues with the bbc iplatey app on my skyq box. The home page cursor is very slow and jerry through the left hand menu causing it to skip past the selection such as selecting search . This only happens on this menu and page and is fine typing after this page. All software appears upto date and I've tried to force update the box manually.My bbc ipayer app on our SkyQ box is working fine be watching over night football maches on it for last couple of days actually , no problem.navigating though the various pages. Definitely not having the problems you describe.
You replied to an earlier post Dave, they've come back since and both posts above yours say it's resolved itself (BBC update presumably). Just checked and mine is fine, it's not something I use much on the Q box, especially for the football as I've got a V2 box so the TV gives me full UHD and Dolby Multichannel PCM 2.0 over the Q box Stereo PCM sound.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
