Discussion topic: Sky box keeps turning off
Message posted on 18 Jun 2025 05:56 PM
My sky box keep shutting down by itself.. I then have to turn it off and start it again.. it also keeps freezing on standby and I have to reset it again.. this has now happened 4 times in that last 2 days .. you can be watching something then it just goes blank.. can you help me with this as I am fed up with having to keep turning my box off then on again.
Message posted on 18 Jun 2025 06:05 PM
Re: Sky box keeps turning off
Hi @Trace344
Is your Q box well ventilated and not stacked with other devices.
It's easy for the boxes to overheat in current ambient conditions.
If this is not the issue, then try a Reset Settings in the Q box hidden menu.
Message posted on 18 Jun 2025 07:18 PM
My Q box has turned itself off twice in last 15 mins - able to restart but this is exactly the same as the start of general Q outage in May - box has worked with out any issues since then
Message posted on 03 Aug 2025 10:53 AM
I've had same issues with my box, after doing all the steps it still continued. Sky have replaced box now but problems occurring again 😡
Message posted on 04 Aug 2025 03:13 PM
Hi,
I've been having the same problem and followed these steps to rectify. Now I have accessibility set up on screen and am not able to reconnect my remote to navigate.
Any suggestions please?
Message posted on 04 Aug 2025 04:27 PM
@Eagles2018 wrote:
Hi,
@Eagles2018 try the following...
Unpair their Sky Q remote from the box by holding 4&6
Wait for the remote to flash you should then be able to dismiss the information screen by clicking on Skip & set up later
Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control your TV.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 06 Aug 2025 07:29 PM
Mine has been doing it for months. It seemed to be happening all over the country then it rectified itself and stopped for about a month or two then recently started happening again
Message posted on 25 Mar 2026 03:55 AM
New Q Box still stopping sounds as though the hard drive or fan is continuous running that's why I replaced it so what's happening.
Message posted on 07 Jun 2026 07:44 PM
- This is happening to us too. Its so annoying the TV is practically unwatchable! Tried the resets, called and had tech support and it will work for a few weeks, then back to switching itself off again and freezing
Message posted on 18 Jun 2026 08:39 PM
Hi i have the same issue when the box goes onto standy overnight crashes then says programme not avaliable meaning i have to unplug it to reset it sky sent me a new box it worked fine for 2 days then the box automaticlly updates and now hey presto doing the exact same every single night anyone find any fixes
Message posted on 19 Jun 2026 07:14 AM
So far nothing has fixed the issue. I've even had my box changed which is a nightmare as I've lost previous recordings
