Discussion topic: Skyq bbc iplayer issues
Message posted on 04 May 2026 07:02 PM
Message posted on 04 May 2026 07:04 PM
Re: Skyq bbc iplayer issues
Message posted on 08 May 2026 09:44 PM
I have exactly the same issue which started a couple of days ago.
Message posted on 09 May 2026 07:55 AM
Hi Mesaboogieman ,
Thank you for confirmation it's not just me.
Does anyone know how we can report glitches in sky apps?
Is it likely to be picked up on here?
I'm not really Interested in sitting on a phone call for an hour explaining myself to 4 different people and getting transfered to the wrong personally the way.
Is there a way of raising a ticket here?
Message posted on 09 May 2026 08:43 AM
Hi @00011000 You could try reporting it to viewer relations by emailing viewerR@sky.uk
Message posted on 09 May 2026 02:51 PM
Thank you for you advice in emailing viewer relations.
Best regards
Message posted on 09 May 2026 10:31 PM
- I have also emailed Sky at the addressed given to report this issue.
Message posted on 14 May 2026 03:16 PM
Tried the apps reset and reboot as suggested by customer relations but problem is still present. Have now been advised to telephone Sky support. Anyone fixed this issue yet?
Message posted on 19 May 2026 04:31 PM
Same issue here. It seems to be since the BBC added football as the second option in the left hand menu.
Once you get to the content it plays just fine, but the navigation is like wading through treacle.
Message posted on 19 May 2026 04:40 PM
Yes, I also think it might have something to do with the addition of the new world cup football icon to the main menu. The problem was present for me a few days before this new icon appeared but that was probably stage 1 of the process before actually adding the icon.
Message posted on 19 May 2026 04:54 PM
I'm the same as you.
On email they suggested refreshing the apps which is accessible from a secret menu and checking for software updates.
Neither fixed the issue.
Message posted on 29 May 2026 10:32 PM
Mines exactly the same. It seems sky dont care very much about their subscribers, otherwise they would have fixed this.
Message posted on 30 May 2026 07:31 AM
I'd imagine that the iPlayer codebase is maintained by the BBC rather than Sky.
Sky should have QAed it though before allowing this version of the app through.
Message posted on 30 May 2026 08:47 AM
@trumpet59 wrote:Mines exactly the same. It seems sky dont care very much about their subscribers, otherwise they would have fixed this.
Absolutely nothing to do with Sky, have you complained to the BBC? The final test for any software is releasing it to the public as the user base is exponentially larger than any in-house team. Everyone should use the link for viewer relations given earlier but ignore any recommendations to change anything on the box, that won't help but at some point they will pass it on to the BBC who need to update their own app.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access with MLO enabled, main Deco hardwired to Max hub
Message posted on 30 May 2026 02:35 PM
If that is the case the BBC app works perfectly on every platform except Sky. You would expect Sky to drive any issue with them no their users
