Discussion topic: SkyQ cable from the dish
Message posted on 27 Jun 2023 03:35 PM
Hello I do apologise if this question has been asked before.
I am upgrading from SKY+ (looking at my dish/receiver there are two wires.
my question is does this cable work in SKYQ or will it have to be replaced?
Message posted on 27 Jun 2023 03:37 PM
Re: SkyQ cable from the dish
@Horseybird As long as the cable is in good condition it will be reused, the LNB which is on the dish will need to be replaced for Sky Q
Message posted on 27 Jun 2023 03:48 PM
Brilliant. The wire goes from the dish down the wall. Then under the floor to the area where the old sky+ box it. There is enough cable to put néw connectors if required.
Many thanks for your help👍
