Discussion topic: HD or UHD
Message posted on 27 Jun 2023 02:07 PM
HD or UHD
I'm currently paying £9 per month for the HD package. However, I also pay for Sky Q which seems to come with UHD package for free.
Do I need to pay for HD also or should I cancel that?
Message posted on 27 Jun 2023 02:15 PM - last edited: 27 Jun 2023 02:16 PM
Re: HD or UHD
hi @LauraK1985
There is no SKY Q specific charge - all the costs are for subscriptions to the TV channels & UHD is not free
The box may be UHD capable but to use UHD on SKY channels then you must have both HD and UHD subscriptions
Message posted on 27 Jun 2023 02:34 PM
Re: HD or UHD
The UHD subscription does not cover HD as well.
Sky typically now bundles them as an option when building a Q subscription package
Message posted on 27 Jun 2023 02:48 PM
Re: HD or UHD
Thanks for your answers. Apologies for the confusion - I meant the multi-screen package (with Sky Q) seems to give me UHD.
As you can see from the screen shot below, I have Sky HD and Ultra HD. So, if I cancel the HD, would I still be able to use the Ultra HD?
Message posted on 27 Jun 2023 02:52 PM - last edited: 27 Jun 2023 02:52 PM
Re: HD or UHD
That was the case with the Entertainment baseline product, but not for Signature
I think you effectively have the 'Ultra HD + HD' add-on, so that would remove both.
Message posted on 27 Jun 2023 03:17 PM
Re: HD or UHD
Hi @LauraK1985 - unfortunately there is an error in the pop up information screen that shows if you click on the multiscreen info button - it still says
Enjoy Sky on a second TV & on 4 devices with Sky Go, plus get UHD on your main box
which as @TimmyBGood says is no longer the case - with Signature you need both HD & UHD add ons
This wording error has been reported but clearly not yet reached those who need to correct it
