2
This discussion topic has been answered Discussion topic: SkyQ cable from the dish
This message was authored by: Horseybird
Hello I do apologise if this question has been asked before.
I am upgrading from SKY+ (looking at my dish/receiver there are two wires.
my question is does this cable work in SKYQ or will it have to be replaced?
This message was authored by: GD1 Answer
Re: SkyQ cable from the dish
@Horseybird  As long as the cable is in good condition it will be reused, the LNB which is on the dish will need to be replaced for Sky Q
Avatar for Horseybird
Level 2 icon
Brilliant. The wire goes from the dish down the wall. Then under the floor to the area where the old sky+ box it. There is enough cable to put néw connectors if required.
Many thanks for your help👍
Answered - Go to Answer
