Discussion topic: When I watch tv from the sky mini box , the picture keeps on freezing
This message was authored by: sawitree+onprom
Either recording or live tv the picture freezes
Re: When I watch tv from the sky mini box , the picture keeps on freezing
Hi @sawitree+onprom
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
