Discussion topic: SkyQ Mini
This message was authored by: N1ck+D
SkyQ Mini
Sky Q mini box is on but no picture is showing on TV
HDMI 1 port is showing as connected but no picture is showing on TV
I had to change batteries on SKY remote and now no picture on TV
Re: SkyQ Mini
Hi @N1ck+D
Reboot the mini as above.
If you cannot switch the mini on with the remote try pressing the Standby button (Amber led) on the front of the mini.
If this brings the mini back on then Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
