This discussion topic has been answered Discussion topic: Switching from Sky Q to LG OLED 55 C24
Message posted on 09 May 2023 04:19 PM
When my contract runs out, I'm looking at ditching Sky Q. My TV supports Freesat but will I need to change my Sky Q LNB for a different model.
I've plugged one of the cables in and it's done a scan, it lists over 130 TV channels and can get the egp, but every channel reports 'invalid signal' which makes me think I would need a different LNB. The TV only accepts one cable.
I can't find anything within LG documents and their phone support wasn't that good.
If I need a separate LNB do I need a specific one? Could I move cable and wire into my old LNB on my other dish (Sky never seem to take older dishes down and just put up new dishes.)
Mobile: Apple 16 Pro Max 512GB|Samsung Tab S6
TV: LG OLED55C24LA|Freesat 4K|2xHDHR Quatro
AVR: Marantz NR1711
Streaming Devices: Xbox Series X|Apple 4K TV|Fire TV Cube|Shield TV Pro|Roku 3
Message posted on 09 May 2023 04:37 PM
@mirdragon wrote:When my contract runs out, I'm looking at ditching Sky Q. My TV supports Freesat but will I need to change my Sky Q LNB for a different model. YES
I've plugged one of the cables in and it's done a scan, it lists over 130 TV channels and can get the egp, but every channel reports 'invalid signal' which makes me think I would need a different LNB. The TV only accepts one cable. You would need to change the Sky Q WIDEBAND LNB for a Legacy UNIVERSAL LNB
If I need a separate LNB do I need a specific one? Could I move cable and wire into my old LNB on my other dish. YES
You will need to feed your Freesat TV from a Legacy UNIVERSAL LNB, and there is a strong possibility that this is the type of LNB was fitted to your old satellite dish.
Message posted on 09 May 2023 04:44 PM
Re: Switching from Sky Q to LG OLED 55 C24
Thanks for that, I had a feeling that would be the case, but would it be same if I decided to get a Freesat box instead? Don't the newer ones works with Sky Q LNB?
AVR: Marantz NR1711
Message posted on 09 May 2023 04:47 PM - last edited: 09 May 2023 06:04 PM
The 'Freesat 4K' branded boxes do.
Unfortunately manufacturers are still fitting older (and presumably cheaper) satellite tuner components even into 'premium' range television sets and so these can't get a Freesat signal through a Q LNB.
