3
This discussion topic has been answered Discussion topic: Sky viewing card
This message was authored by: Stuart19621
Sky viewing card
Please can a a sky viewing card be sent to me as I unfortunately left my old one in the old box when it was collected yesterday thank you
This message was authored by: SKY1992bf Answer
Re: Sky viewing card
@Stuart19621  You will need to contact sky direct to request this as this is only a customer community with no account access
These are the current methods for contacting Sky…
▪️call by dialling 150 (free) from either a Sky Talk landline or a Sky mobile.
Calls to Sky will start automated which may offer you the online help route (see below) or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
▪️online help via this link
https://www.sky.com/help
▪️ Sky Assistant is also available at the top of sky.com/help for most service issues and gives you 24/7 help and a quick response. It will provide you with multiple choice options based on your problem and will provide troubleshooting steps to fix any service issues.
▪️Social Media You can also get in touch with Sky via the messaging services on: Facebook or Instagram (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
@Stuart19621
You aren't the first to do this and certainly won't be the last.
This isn't something the Community Messaging Team can help with so as advised by @SKY1992bf you'll need to call Sky to order a replacement viewing card.
Saying nothing when the automation (bot) kicks in sometimes gets you to an agent.
@Stuart19621
Your new thread has been deleted as you asked the same here on Saturday and received the correct information.
Answered - Go to Answer
