This discussion topic has been answered Discussion topic: Sky update taking forever!
Message posted on 25 Mar 2025 01:35 PM
For reasons that are too long/boring/irrelevant to go into, we have been paying for Sky for the past 13 months but have not been able to use it and the box was packed away. Today I reconnected our sky box and it says we have no satellite signal (I have managed to connect the box to WiFi).
The service checker online, however, says we do have signal but need a software update (box says it's using software version Q230. 000.14.00L (5nf3ptk)).
The software update has now been going on for about an hour and all it says is "software update in progress" - is this normal? There's no indication of how far through the process we are so I don't know whether to wait it out or reboot...
Message posted on 25 Mar 2025 04:57 PM
Hi @Elly10 There is a chance that the software is so far out of date that it cannot be updated. There has been at least 5 updates since Q230.
Message posted on 25 Mar 2025 02:13 PM
Re: Sky update taking forever!
Hi @Elly10 The software only updates when you place the box into Standby. Normally about 30 minutes after requesting it.
Message posted on 25 Mar 2025 02:15 PM
Thanks for your response! I am trying to "force" an update through settings - it's telling me not to turn off the box, so I didn't think I could put it on standby?
Message posted on 25 Mar 2025 02:17 PM
Message posted on 25 Mar 2025 02:19 PM
Ah grand - I shall try that then! Thanks for your help 😊
Message posted on 25 Mar 2025 04:25 PM
@MightyQuinn wrote:
@Elly10 wrote:Thanks for your response! I am trying to "force" an update through settings - it's telling me not to turn off the box, so I didn't think I could put it on standby?
Hi @Elly10 Not to turn off the box means unplugging it from the mains.
Ah sadly that hasn't worked either. I shall just wait patiently for an engineer visit ☺️
Message posted on 25 Mar 2025 05:00 PM
@MightyQuinn wrote:Hi @Elly10 There is a chance that the software is so far out of date that it cannot be updated. There has been at least 5 updates since Q230.
Haha that would be just my luck! Thanks for all your help - appreciate it!
Message posted on 25 Mar 2025 06:03 PM
@Elly10 If your box has not received a satellite signal for a while it will not work(the box needs the periodic keep alive satellite signal) but if you leave it connected to the satellite it should then receive this signal and start working again once your box receives this signal you should then hopefully be able to update it but untill you receive the signal nothing will work
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
